Wing covering
Before covering my wing I did some research and watched several videos. Very informative but I may have missed something. Basicly the instructions say to seal the edges and then shrink the middle. Before shrinking the middle should the iron be run over the ribs to stick the Monocoat to it or just shrink the entire center? As a side note I have a non-contact thermometer that I used to check the temp of the iron. Temps came up fast in the middle but the toe and heel took a while to reach a usable temp. In other words I needed to let the iron set for a while before it was able to do the job across the face.</p>
