RCU Forums - View Single Post - converting air to electric retracts.
Old 02-01-2013 | 09:28 AM
mustang493
Default RE: converting air to electric retracts.
And another foot note.  One of the main advantages of this type of gear is when the gear is fully extended and fully retracted there is no movement in the leg.  The screw jack winds the gear tight against the stops and takes all the play out.  The disadvantage is the speed it takes to raise and lower the gear and another consideration is g load.  if the aircraft is pulling significant gs the gear will stall going up... one thing to watch for.  <div>
</div><div>The retracts are being fitted into a Mick Reeves English Electric lightning.  I'm about a couple of week away from the first test flight.  fingers crossed it goes well.  i'll post a video of the maiden flight.   </div>
