RE: choices
SBOT you can get a fox 15 USA made, fox is one of the best from Davis with the original glow head and his diesel head the fox is a nice set up on the carb it is mounted on a flat
plate and c/l and r/c carbs quickly change out 2 screws, if you have a clunker you can trade it in to Fox and just get the Davis head for it
The Fox is of course made in the USA one the best out there martin
of course in the classics the PAW good choice both PAW and Fox are factory run
MVVS is a great engine however as pointed out supply of engines and parts limited I do have them the
09,15,40 AND A 60 ALL DIESELS NO ISSUES
in the wee ones MPJET 061 is back Davis Owen in Australia and I Care RC Quebec has them -fantastic engines
When you time go back in time on the posts you see all the engines, results, good and bad, fuels, props for each one, pix and videos
quite informative
