RE: Glow engine setup for IMAC
When I had my DP Extra with a Moki 1.8, I had a Perry VC-30 pump that ran off crankcase pressure. Fuel tank was on the CG and the combo was bulletproof. There's no need to be concerned about tapping the rear of the crank case; once you get the pump set up, you'll never want to remove it.
