RE: Giant Sweet and low stik
OK, 1st Pic is just adding the other spar. the 2nd pic adding a thin trailing edge. I will be adding 1/4" square in between each rib to strengthen it and give a little meat for the hinges. The last pic is adding a little trailing edge sheeting. I know myself well enough to know that if I did not do this I would be snapping parts off left and right every time I moved something. I repeated the process for the other side so now left and right are at the same stage.
