RCU Forums - View Single Post - Mike McConville Rules!
Old 02-02-2013 | 08:50 AM
baronbrian's Avatar
baronbrian
My Feedback: (13)
Default RE: Mike McConville Rules!
ORIGINAL: 19th Alta Dragoon
Mike ,
I have the Hanger 9 Funtana 125 with a Satio 125 and the plane flys good , trims out but you cannot land it. Just as soon as you back of the throttle the nose goes up at a 45 degree angle . The Plane is balenced according to the directions . Three times I have attempted to land and had to reapir the the under carrage, but to no avail. If you are running full throttle of half throttle on level flight and reduce power the nose goes up . Any suggestions on this one ?
Bob Irwin
Canada
Add a few degrees of upthrust to the engine and it will be much better. Just a washer on each side of the bottom of the mount on the mounting bolts and in between the engine mount and the firewall and you should be set!
