RCU Forums - View Single Post - Noob to War Plane
Old 02-03-2013 | 02:05 PM
dce21b
Default RE: Noob to War Plane
ORIGINAL: GaryHarris
ORIGINAL: dce21b
ORIGINAL: JohnBuckner
For all the airplane you are interested just as I first posted you need to get the idea of starting with gas engines out of your head, that wiill only slow down your progression.
Also I would avoid the OS.46LA as a branch in the spokes of your wagon. It is a reliable engine but very weak in its class and even user friendlyness when compared to the best OS offering in that class and those engines are the AX,s The .46AX series 11 or even the .55AX.
The AX most all of them are superb engines and yes far more expensive but if you really want a fast track to climb that skills ladder then these are engines you want. In addition they will be far more employable for later airplanes.
John
Yeah blameflyinwalenda for that... lol.
I do want a 4 stroke though... what are your thoughts on this?
http://www3.towerhobbies.com/cgi-bin...LXXRH2&amp;P=7 <br type="" />
I have had 4 of them and only had trouble with one of them. A $2 rocker arm screw after about 4 gallons. I'm about to order another one for my LT40. BTW, you can find them cheaper.
http://www.hobbypeople.net/index.php...ke-engine.html
Sweet... Im currently making a shopping list based off of the user manual for the Eagle 2, I like the way it looks and it has alot of the options I want in a kit. I will post my final shopping list for electronics motor etc later tonight hopefully and you guys can critique.
<br type="_moz" />
