RCU Forums - View Single Post - Kaos E-Konversion
Old 02-03-2013 | 07:53 PM
doxilia's Avatar
doxilia
Default RE: Kaos E-Konversion
ORIGINAL: Take2Flight
You may be right about the electric vs piston propeller thing. Unfortunately my motor is redlines at 700W and I am too far down the road to change now. I am thinking I will fly the Kaos with this setup to get the feel of it and then maybe go back to the drawing board for Mark 2 with a hotter motor.
On closer inspection of your motor picture, it appears to be more of a 32 sized motor - 4250 or so I imagine. What really surprises me is that it redlines at 700W if it can take 6s! That is quite unusual for outrunners. With a low KV it can be done evidently.
On these birds with trike gear, we are usually aiming at high rpm on smaller props compared to the typical electric wisdom. The idea is to use higher KV motors that will get a smaller prop up to speed and produce good power. An identical motor with a higher KV of say around 800 would have delivered the extra Watts one might be looking for and get it into the ~900W range. 150 W/lb or more is nice on a classic for excellent performance. So you'd be aiming for 750-800W at full throttle. Your setup will be similar to the performance of a typical early 80's 40 size engine like a K&B 40 rather than a modern 46.
That said, your model will fly just fine, it just won't be quite the performer that it could be. If you decide to retrofit another motor later for more performance, you might also want to consider mounting the motor with the typical X-mount to the firewall. This is generally a more solid solution on these power ratings and it will also keep the lines of the plane cleaner. The prop adapter mounts to the can of the motor rather than using the shaft off the back. Some simple 3/8" hardwood dowels or aluminum standoffs can put the motor at the desired distance from the FW.
Enjoy!
David
