RCU Forums - View Single Post - Write-up: DLE-20 reed valve block mod
Old 02-04-2013 | 07:03 AM
grosbeak's Avatar
grosbeak
Default Write-up: DLE-20 reed valve block mod
Follow up to Write-up: Installing a Bowman ring in a DLE-20
From Frank:
All China engines reed Block Mod.
I found that on the rear intake's there is a Black plastic or Aluminum reed block between engine & carb. It has a flange on it for mounting to flat carb & engine surface and reed part is triangular shaped. The reed block surfaces are not flat and reeds in some cases don't lay perfectly flat against block. The gasket surfaces often times are not flat either and need to be sanded down to flatten. In some reed blocks there are 2 screws that go thru a steel plate that holds reed to surface. On other reed blocks the screws just go through holes in reeds. Remove screws and reeds from block, then file or hone metal plates if supplied flat as 1 side will have burrs from having been punched out and holed not drilled. Next tape down 320 grit sandpaper to edge of really flat surface, table top, edge of thick piece of glass, etc. Because of the lip on plastic block, let that part hang over edge and pull plastic or Aluminum block across paper to flatten. Repeat on other surface until the surface is flat. It won't take much so no need to get carried away. Next deburr the 4 screw holes as screws tend to pull plastic up in screw holes. Remount screws thru plate & reed or just reeds. Make sure reed is totally flat, if not remove screws again and turn reed over and reinstall screws. Screws will strip easily so if you have lock tite you can put a tiny bit on screws to secure & tighten gently. What this affects is idle, engine will be hard starting as if 1 or both reeds are open ever so slightly, fuel won't be drawn up to carb and stay there. If reeds are open it never will pull a vacuum to draw fuel and hold fuel at carb. Thanks Frank
It is assumed at this point that the engine is removed from the airplane.
1. Remove the back plate bolts
2. Remove the carburetor and back plate from the crankcase.
3. Remove the two bolts that attach the carburetor to the back plate and separate the two components.
4. Remove the reed valve assembly from the carburetor block.
