RE: how you can tel polyester from epoxy fuselage?
You can get good epoxies to stick, no problem. You just have to clean with acetone, sand and clean again with acetone to make sure you get rid of any blush and get enough tooth fro the epoxy to stick - 80 grit paper is what I've used with Hysol and it stayed until the end...
