RE: *ASM Cessna 182 (10ft) 30-50cc*
Captmicom
It is 55cc single ring on each piston,produces 5.6 hp so they claim,it has plenty of power and pulls the Cessna around on half throttle even less if you want with 22x10 prop,it is off the ground in no time using half flaps too,i have 3 subC batts on the firewall,2 are 6v for radio and lights the other is 4.8v for ignition,if i remember i have around 2 lbs of lead just behind the firewall,hope this helps
Ian.
