RE: Mix Elevator with Throttle for Scale Flight?
Thanks RCKen.
The mix is set for low to moderate throttle onlyso as you increase throttle the elevator returns to the original trimed position. You also have the option of turning the mix off and on as desired by programing the mix to a switch. I see this as flying the plane at crusing speed by having a little elevator on the throttle in stead of the elevator stick and/or elevatortrim. Kind of like have a high speed trim and a crusing speed trim without the constant manual input of up elevator. For landing you can turn the mix off and use flaps at their usual setting.
Thanks again for your input.
