RE: Power Box Royal Setup Question
Occasionally one servo is slightly different than the other, but this can be checked by taking them out and testing the throw and movement next to each other through the power box. If the movement is matched then the problem is horn position or geometry. Small differences in linkage angle, horn position (sometimes due to servo mounting) can cause this.
