RE: Noob to War Plane
Ok I will go with the .46 then... I have the whole tim allen "more power" syndrome lol.<div>
</div><div>Would you suggest getting analog or digital servos? I know the difference between the to but didn't know if this would be overkill for a trainer that I assume wouldn't need such precision.</div><div>
</div><div>Here's the two I am looking at... also any other suggestions would be appreciated. </div><div>
</div><div>Digital</div><div>http://www.advantagehobby.com/114216/SPMSA6000/?quantity=4</div><div>
</div><div>Analog</div><div>http://www.advantagehobby.com/178334/SPMSA6050/?quantity=4</div><div>
</div><div>I am planning on doing dual ailerons and would like to have the ability to use flaperons. When setting this up would it be better to have both aileron servos on the one channel via y cable or would it be better to have each aileron on its own channel?</div><div>
</div><div>The reason I ask is cause the spektrum reciever is 30 bucks for a 4 channel... like 60 for a 6 channel</div>
