RE: Problem with UAT tank. how to correctly set up fuel system
Hi Ulrich
For straters try these:
1 - Do not use a screw in the fuel fill line. Threads will allow air to get in.
2 - Change the tygon tubing for PU. DO Not use tygon pluged in Festos
3 - Change the Festo filter. They tend to brake and let air in. Keep using the filter and manual valve in the pressure side.
4 - Make sure there are no restrictions and filter in the clunk
Regards
Nuno
