RCU Forums - View Single Post - Problem with UAT tank. how to correctly set up fuel system
Old 02-06-2013 | 08:56 AM
uixkes's Avatar
uixkes
Default RE: Problem with UAT tank. how to correctly set up fuel system
Hi all
that was a quick and easy fix. I think I got the problem sorted.
It was indeed the screw in the filler line and I replaced it with a short rod.
I filled up the tank and started the pump running the fuel into a canister. After several minutes still no air in the line, CAT full up to the top.
Great result. Thanks again for your help.
Ulrich
