RCU Forums - View Single Post - Noob to War Plane
Old 02-06-2013 | 12:29 PM
  #80
dce21b
Default RE: Noob to War Plane
ORIGINAL: JohnBuckner
No neither of those batterys would I ever use. At least not a full house airplane (meaning at least four servos or more) or posibly just a small parkie.
I would never use a four cell pack for any 2.4 system only five cell this especailly so with Spectrum that had all those early brownouts when the fellows used four cell packs. The capacity you choose is fine but I would also suggest five cell Nimh. Five cell Nimh is what I use in the majority of my fleet.
Regarding polarity that does not make any sense are those batterys not center pin l positive? The only reverse polarity that I am aware of currently is the long standing and irrational penchant for JR to use a centerpin negative two conductor charge jack on their transmitter not the Rx pack.
John
Ok I will look for a 5 cell nimh pack.... I was a bit confused on what was compatible with what when it comes to plugs and everything. Unfortunately it seems Spektrum stuff is a bit expensive so I was looking for other name servos. Anyway I was reading a thread that said they were supposed to make universal connections a standard among the different manufactures. They said that you had to file off something on the servo plugs and they would fit fine into spektrum receivers. But the one thing you had to be careful of was pluggin in JR connection into the receiver cause the polarity was different.
I cant remember where I read that but thats basically they were saying.
<br type="_moz" />
