ORIGINAL: uixkes
Hi all,
I would appreciate some help and advice.
I tested my JetsMunt VT80 for the first time and wow! what a great turbine.
I primed the fuel line and the turbine started without any problems. The turbine was running for a short while until I noticed a lot of air bubbles, so I shut the turbine and let cool down.
I noticed the UAT tank was only half full (or empty
and was not filled up by the main tank.
I don't understand this as I fill the main tank through the UAT tank.
My setup is as follows:
Main tank has a vent tube (exiting through the bottom of fuselage) and a tube to the UAT tank.
UAT tank has a tube to the pump and a filler plus the tube from main tank
When I fill the tank I see that the UAT is filled up to the top and then that main tank gets filled. I have no air in the system.
As I mentioned I started the turbine and the turbine was running until the UAT tank was down to half full and then bubbles appeared (probably that is where the clunk sits)
Maybe I am missing here something stupid but why is the fuel not drawing from the main tank to the UAT? The main tank is filled through that tube.
I hope you understand my problem. Sorry if I can't explain it better.
Any advice and help would be appreciated as usual.
Ulrich
