RE: Hangar 9 30cc P-47 Build Thread
Hi again !!
If you are to use the 30cc U/C in the Razor-back,I think that you will end up with a bird sitting a bit lower to the ground and you may have to alter the retract -bay with respect to where the "scissor" joint positions itself in the bay.
The other alternative is to convert your "machanical / pnuematic" retracts to elactric by using LADO actuators...........Easy and they are plug and play,this is what I have used in my build.
Good luck........
Cheers............Nick (UK).
