RCU Forums - View Single Post - Problem with UAT tank. how to correctly set up fuel system
Old 02-06-2013 | 07:00 PM
roger.alli's Avatar
roger.alli
Default RE: Problem with UAT tank. how to correctly set up fuel system
ORIGINAL: uixkes
Hi E.N.T
I was actually thinking the same. Is it really necessary to fit an UAT?
I guess opinions are divided and everyone has it's preferences.
Ulrich
Hi Ulrich,
How good is RCU?? Almost instance response to help you trouble shoot your fuel system.
I agree that a UAT or a CAT is not always necessary, and a lot of people successfully operate a turbine with out one.
However, look at it this way. If you did not have a CAT fitted, you may never have picked up the air leak that you already had. So your CAT has already done a sterling job for you.
I am in favour of air traps. I make it a habit to check my UAT after every flight. If the air bubble is excessively large, this is a sign that a air leak may have developed up stream. They also make a great final filter..
Roger
