RE: OS GT33 shaft dia 8mm vs 10mm prop hole
If you can machine parts, you can machine a piece of brass tubing to the desired inside and outside diameters. You can buy a propeller with a smaller hole and drill it to fit...most wood props are like that. Finally, you can wrap the shaft with tape to build it up.
