RCU Forums - View Single Post - KingTech K-80
Old 02-07-2013 | 10:28 AM
  #1016
bstussie's Avatar
bstussie
My Feedback: (22)
Default RE: KingTech K-80
ORIGINAL: marquisvns
Thanks for bring it up Gus, but the dimensions from the manual is only a reference. b has over 5/8'' from the bell mouth and I would say it should be just fine. I have seen 1/2'' being cooler running, but perhaps has to do with the design of the pipe. Basically, once set up, you wanna run it on the ground at full throttle and take a look at the temperature. If it doesn't over temp on the ground, it would only get cooler in the air.
Regards,
Barry
Thanks for the advice... Hope to maiden it F-16 Sunday!
