RE: Jetcat battery liFe and balance adapter for cellpro charger?
Sorry, can you explain Universal pins?
You can check the battery with a meter, the back of the plug has exposed contacts you can get to with a pointed multimeter connector. Either end wire will be the negative
Dave
