RE: JET LEGEND VIPER BUILD THREAD
Hi all.
I got thesmoke pump working.
If you buy the jet legends one, which is great value, (with everything you need including tanks). It comes with 3 wires off the back of the pump. 1 red + 1 black - in 1 plug and and 1 white signal in another.
If you haveapower boxthen no problem, just putthe the white into the channel you will switch the pump on with, the other plug with the red and black into any spare port. That will then draw off the rx packs...(about1/2amp draw)
If like me you have a standard rx and are using a seperate switch and battery pack for the pump, then you split the black wire, solder in another black wire with a servos pin on the end, and fit this into the plug with the white wire.
Now you have 2 plugs, 1 with a red and black, the other with a white and black.
The white/black goes into the rx on wharever channel you are using.
The red/black plug goes through a switch to a seperate battery.
All working great now, which ever system you use.
