I did a quick CG check and it looks like it will CG right on the spot, the 2000ma NIMH batt will be sufficient to balance it if needed. So far what I have left to do is to install the pilot and canopy ( glue him on and 4 screws for the canopy ) adjust the deflection on the flaps, instal the on/off switch, glue the covering seams with CA to prevent it from lifting and check the CG.
I should be done by noon and on my way to the field to run the engine ( I will run it at home first before I go to make sure ) and most likely I will be doing the maiden flight ( video for sure )
