RCU Forums - View Single Post - OS Max 60 SR HELP!!
Old 02-07-2013 | 09:43 PM
mbike01
Default OS Max 60 SR HELP!!
Had a mishap and the front drive washer and the prop shaft are goobered up. The front bearing is a standard r6 so the drive washer is @10mm and has a collect to wedge. I cannot fan a washer to replace this one. can i use another one? also the prop shaft screws into the cam and it is a 1/4 shaft with 28 thread count. any ideas where to get. Will buy from one of you guys via paypal if you have the parts i need!!
