ORIGINAL: flandrumjr
Thanks jaka.
I agree, it is not a necessary element for typical flight for a person, like myself,who enjoys <u>scaleflying </u>and has the plane<span style="color: rgb(255, 0, 0);"> <u>correctlytrimed</u>at a particularspeed</span>, which is the primary reason for exploring the idea. I would like to have the ability to reduce speed, somewhat, and maintain elevation by having a little elevator automaticly "trimed" in when the throttle is pulled back. I,m notlooking for a way to balance the rate of speed with rate of elevator through the entirerange of the throttle to maintain elevation. That would bevertually impossible I would think,just slow the plane a little without having to constatnly apply up elevator or deploy flaps to maintain elevation.
Correct me if I wrong, but when in "auto pilot" on modern full scale planes (I'm not a "real" pilot), when the power is reduced or increased for that matter (to a certian degree), the elevator and / or flapsare automaticly adjusted without pilot in-putto maintain the desired elevation. Like AA5BY said "modern radios make life easier for us" so why not enjoy andexplore the possibillities.
Thanks for your resonce.
To AA5BY and jester_s1;
Very interesting discussion, I have learned alot from you exchange. As stated eariler, all my plans (scale models), to my knowledge, don't have a seriousthrust line problem and are balanced near the recommended CG andto my particular methoid of flying, just experimenting with an idea. Thanks for your insite.
IMO if the airplane is trimmed so that at lower speed it requires up trim and higher speed it requirers down trim then it is not trimmed correctly. I get where you are going with wanting to use mixes to compensate but in reality a mix for your CG being too far forward is not going to work. The problem is that the mix is instant and your airspeed changes are not. The idea would be to set the CG so that anything from about 1/3 power to full power does not induce a pitch change. Right now I'm betting that you carry some up trim. At full throttle the trim is more effective and makes the model climb. At lower throttle settings the trim is less effective and the model dives. Move the CGback some and I'm sure you will see what I am saying.
