Probably tracable to the switch or battery lead.
I had similar problems, glitches, mini hits on a model. But only when inverted.
Couldn't find the answer, kept on flying then lost it during a low inverted. Totalled.
Only after doing a complete wreakage PM did i see that the plastic wire coating had worn away on the battery lead and was shorting out as it moved from upright to inverted.
Increadble to think a loose wire will wear down over time.
Well they do.
