RCU Forums - View Single Post - Yet, another Kadet LT40 build.
Old 02-09-2013 | 03:51 PM
  #64
GaryHarris's Avatar
GaryHarris
Default RE: Yet, another Kadet LT40 build.
ORIGINAL: acdii
You sir are doing good! That is how I built my wings too, tack em up with CA then use Titebond for the joints. That Kadet wing has smacked several hard items in the past year, and only cracked the leading edge and ribs in front of the main spar. Easy fix and back in the air. <div>
</div><div>For the wing servos, if you built the 4* the mounts and cable run for that plane should work fine on this one. The ARF uses a plastic server tray that puts the servo on its side so the arm sticks out of the wing, and I copied that on the kit 4*120, and also using it for the Chipmunk I am building. </div><div>
</div><div>What you can do is glue some rails on two ribs where you plan to put the server, then make a plywood hatch to fit between the ribs to mount the servo to, then screw the hatch/mount to the rails, and wala, done. For the cable feed, just roll up some paper, and slide it through the holes. </div><div>
</div><div>You can sort of see what I am referring to on my 120 wing here,</div><div>
</div><div>[img][/img]
</div>
Thanks bud. And that's what I'm doing. I tack it up then nail it down with Titebond. While waiting for the glue to dry on the left wing half using gravity, (Flip, Flop, yanno the drill) I'm working on the right wing half. I should have the wing finished tomorrow beside the filler in the center section.
