RCU Forums - View Single Post - New Alpha 40 Prop Problem
Old 02-09-2013 | 09:23 PM
smitdoshi
Default RE: New Alpha 40 Prop Problem
OK so i found a threaded nut that fits perfectly on the plane and we are all good on that. <div>I did however come across another issue!!! </div><div>I am having a hard time turning the motor on. i was able to get it to come on two times and had it running fine. The problem is it is now taking me about 20 minutes to get it to power on. i unfortunately do not have that power starter, </div><div>1) i put my glow stick on the glow plug. </div><div>2) spin the prop about 6 times </div><div>3) turn on the remote and put the throttle about half was (i have tried all kinds of throttle)</div><div>4) spin the blade with the start stick</div><div>
</div><div>The plane seems to want to turn on for a split second but doesent get going. </div><div>Was just wondering if there is an easier way of doing this or a better way?</div><div>any suggestions?</div><div>Thanks </div><div>
</div>
