RE: Name this tool
Yes it is a soldering tool, most likely made of teflon. And yes, the pointed end is to keep the holes in eyelets and some types of wire ends or PC pads open as you solder around them or are removing old wires prior to installing new ones. I have both, the metal and the teflon ones and use them quite often.
