RCU Forums - View Single Post - Charging batts inside plane
Old 02-10-2013 | 11:57 AM
BlueBus320
My Feedback: (57)
Default RE: Charging batts inside plane
From what I'm reading on LifePo packs, you probably couldn't get them to catch fire if you tried. It seems the highest possibility will be to puncture them. I can not find a single incident of a Life pack catching fire inside a model, So I am leaning toward carefully charging them inside on my aircraft, unless I can devise the setup I want & figure a way to remove the 3packs. Joe- that's some very good info, & Dave, this is for my UF.. If I place my 2-2100mah bats in the standard location with my P-100rx, I will have to add lead, & I HATE, HATE, HATE LEAD!!! so I'll probably shift the batts into the nose & figue a way to extend the balance leads, then charge carefully & watch them like a hawk. thought about making the nose removable with a batt tray, then I could remove & charge all 3 batts, but dont really want to add the weight of that either
