RE: Interesting problem ...input invited
Well I could not find anything wrong during my bench testing so......I removed everything from the plane, all of the servos, the switch, the battery pack and the two extensions and replaced everything even the 2.4 receiver got some new padding.
Went out today with hopes of it being fixed but still a bit gunshy of bringing it down in the same spot where this has happened 5 times already.
I flew around high for a few minutes and everything was OK. I came down and approached the area where this has happened before and BANG the elevator goes full down and returns to neutral and AGAIN here I go inverted in the opposite direction.
I push down elevator , got it upright and BAM again it goes down elevator and inverted. I manage to get it upright again and now I'm trying to bring it down and land when BAM again it goes down elevetor inverted about 10' from the ground and now it was was far away from me close to the ground and I magaged to get it upright but there was not enough air space left .
I fixed it good this time.
