RCU Forums - View Single Post - Yet, another Kadet LT40 build.
Old 02-10-2013 | 07:53 PM
  #67
GaryHarris's Avatar
GaryHarris
Default RE: Yet, another Kadet LT40 build.
In order to use a "Pull-Pull" cable system for the tail dragger design, I will be flipping the top rear section of the fuse so that the push rod exit for the rudder will now be on the starboard side instead of the port side. (Just like the LT25). This should be the easiest way to keep the rudder and the tail wheel going in the same direction. (Yes, I messed that up before).
The tiller will be designed as I go and as much as I would prefer to use the shortest cables possible, it will be much easier to work through the open section of the main area and also keeping the weight of the tiller as far forward as possible. The problem is fishing those cables through the fuse. I may add some outer housings for the cables.
