RCU Forums - View Single Post - Charging batts inside plane
Old 02-10-2013 | 11:01 PM
BlueBus320
My Feedback: (57)
Default RE: Charging batts inside plane
ORIGINAL: Dave Wilshere
Depends on your Rx Li-Po sizes The battery pockets we devised on the Flash range is where my batteries sit. With a P-100 (lighter) you should get away without any weight. I build the model and select battery capacity to make up the weight!
Dave
Agreed 100%, best technique going! I'll do my fancy textured paint/carbon fiber deck I want, then see what batt position works. MAH=good ballast (Much better than lead).. But as far forward as possible = less MAH & weight necessary to get it done.
