RCU Forums - View Single Post - DX18 Binding Problem
Old 02-11-2013 | 02:27 PM
Rob2160's Avatar
Rob2160
Default RE: DX18 Binding Problem
Some things to try...
1. is the Bind plug in the correct port?   I had two identical JR receivers, and one binds perfectly with bind plug in the marked bind port.. the 2nd RX did exactly what you described if I put the bind plug in the marked port.. It turned out that the actual bind port was on the oppostive end of the ports and using this position (incorrectly marked on RX) worked perfectly..
2. correct polarity of the Battery on the RX?
3. DSMX or DSM2 modulation set in your radio?  It won't actually make a difference because the RX will / should bind either way.. but select DSMX because it is a better protocol ..   ( whatever your TX is set to will not affect the RX flashing in bind mode)
HOpe that helps.. Please post if you fix the problem.. just out of curiosity..
</p>
