RCU Forums - View Single Post - DLE 35RA ignition system question
Old 02-11-2013 | 03:32 PM
BubbasanJohn's Avatar
BubbasanJohn
Default RE: DLE 35RA ignition system question
ORIGINAL: Indiomike
Bubba
I have a DLE35RA but haven't installed it in a plane yet.
I looked inside the plug boot and can see what looks like one or two wires going across the tiny hole at the top of the boot cap. The top of your spark plug should make contact with the wire.
I have done a replacement of the boot cap on a DLE20. If it utilizes the same method as the DLE35 you will have a resistor that will stick into the core of the ignition cable on one side and the other side ( that your spark plug will touch) will be a wire that touches a tiny spring in the top of the cap.
I don't see a tiny spring in mine but I do see a wire that the spark plug would touch.
Mike
Yeah no spring in mine or wire. Must be defective.
