That plane would be a good option for starting out. I started on something similar. The one limitation you have is that because that plane is very light, you'll be limited to very calm days for flying. The slightest bit of wind will create a lot of work for you and will slow the learning process.
If you're willing to spend a bit more, you can go this route
http://www3.towerhobbies.com/cgi-bin...I=LXSGY1**&P=7 and have a more substantial plane that is suited for a greater range of flying conditions. The plane will fly more stable and you may learn faster.
