RE: Ultra Stick - Quad Flaps with 6XAS
Actually, you can connect the flaps in the center to channel 5 gear switch. Although you will have no proportional flap control, you can then use the outer ailerons as spoilerons or flaperons.
You CAN do crow with the 6X, if you don't have retracts.
