RE: compression testing
With chainsaws, you screw in the compression gauge to the spark plug hole, Then pull the chainsaw through compression strokes until the gauge quits rising. This is usually a half dozen pulls.
Most good chain saws will pull 150 pounds. If they get below 120 pounds they are hard to start.
