RCU Forums - View Single Post - wingtip vorticies
Old 09-16-2003 | 01:30 PM
KenLitko
Default RE: wingtip vorticies
If you could build a wing with no spanwise flow, it would still suffer from induced drag whenever generating lift.
Actually, no it wouldn't. The only way you're going to get no spanwise flow is from a 2D wing (a.k.a an infinite wing, or some approximation thereof). The only drag that a 2D wing suffers from is parasite drag.
A 2D wing, has no induced drag because it has no induced downwash. In a 2D wing, upwash always equals downwash... this is not the case in a 3D wing. In a 3D wing, energy is lost (from lift) to the trailing vortex sheet. This vortex sheet induces downwash.
The tip vortex is simply the "rolled-up" vortex sheet caused by a 3D wing moving through a fluid. You CANNOT prevent the tip vortex, but you can modify it. Modifying it by effectively spreading it out further from the other tip (which is what a cutoff, Hoerner, or end-plate does) can reduce drag.
