<xml><w:WordDocument><w:View>Normal</w:View><w:Zoom>0</w:Zoom><w:TrackMoves /><w:TrackFormatting /><w:PunctuationKerning /><w:ValidateAgainstSchemas /><w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid><w:IgnoreMixedContent>false</w:IgnoreMixedContent><w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText><w
oNotPromoteQF /><w:LidThemeOther>EN-US</w:LidThemeOther><w:LidThemeAsian>X-NONE</w:LidThemeAsian><w:LidThemeComplexscript>X-NONE</w:LidThemeComplexscript><w:Compatibility><w:BreakWrappedTables /><w:SnapToGridInCell /><w:WrapTextWithPunct /><w:UseAsianBreakRules /><w
ontGrowAutofit /><w:SplitPgBreakAndParaMark /><w
ontVertAlignCellWithSp /><w
ontBreakConstrainedForcedTables /><w
ontVertAlignInTxbx /><w:Word11KerningPairs /><w:CachedColBalance /></w:Compatibility><w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel><m:mathPr><m:mathFont m:val="Cambria Math" /><m:brkBin m:val="before" /><m:brkBinSub m:val="--" /><m:smallFrac m:val="off" /><m:dispDef /><m:lMargin m:val="0" /><m:rMargin m:val="0" /><m:defJc m:val="centerGroup" /><m:wrapIndent m:val="1440" /><m:intLim m:val="subSup" /><m:naryLim m:val="undOvr" /></m:mathPr></w:WordDocument></xml>
Byron
I don't know just exactly what is different between the lengthy SANYO data sheet and red's clinic. The Sanyo sheet gives you directions on establishing a .1C charge rate at one point. Spog if you could specifically cite the differences you think are significant that would make digesting your opinions easier.
I think that if you follow Red's advice you will be happy with your batteries. You state you are charging your NiMh at 1.6C- that would be 2.56 amps. Since you had 1600mah batteries, I wondered if you were charging them at 1.6 amps or 1C. I think 1C is the max you want to charge them at and you need to be on your toes as you get near the end as Red cautions.
I charge new NiMh batteries at .1c a couple times and though my Dynamite charger has never missed a peak even at .1 I watch their heat as Red had suggested. After they have been in service for a few rotations I then charge them at .5 c and have never had the charger miss the peak. I check them before I go to the field with a loaded volt meter. I check them if I fly a lot while at the field. With 60 to 90 sized sport and scale planes (no 3d) with 5 to 8 standard servos the 2000 mah 6v packs have been good for many flights and plenty of reserve.
Since NiMh don't develop a memory you don't need to routinely discharge them.. But to make sure they still have adequate capacity, before the beginning of the season I use a 10ohm 10watt resister to discharge the packs to 1 volt per cell and then recharge them to see how much the charger had to put back in to get them to full charge. It should be somewhere near the stated capacity of the battery.
Good luck
Mike
<xml><w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true"DefSemiHidden="true" DefQFormat="false" DefPriority="99"LatentStyleCount="267"><w:LsdException Locked="false" Priority="0" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Normal" /><w:LsdException Locked="false" Priority="9" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="heading 1" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9" /><w:LsdException Locked="false" Priority="39" Name="toc 1" /><w:LsdException Locked="false" Priority="39" Name="toc 2" /><w:LsdException Locked="false" Priority="39" Name="toc 3" /><w:LsdException Locked="false" Priority="39" Name="toc 4" /><w:LsdException Locked="false" Priority="39" Name="toc 5" /><w:LsdException Locked="false" Priority="39" Name="toc 6" /><w:LsdException Locked="false" Priority="39" Name="toc 7" /><w:LsdException Locked="false" Priority="39" Name="toc 8" /><w:LsdException Locked="false" Priority="39" Name="toc 9" /><w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption" /><w:LsdException Locked="false" Priority="10" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Title" /><w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font" /><w:LsdException Locked="false" Priority="11" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Subtitle" /><w:LsdException Locked="false" Priority="22" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Strong" /><w:LsdException Locked="false" Priority="20" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Emphasis" /><w:LsdException Locked="false" Priority="59" SemiHidden="false"UnhideWhenUsed="false" Name="Table Grid" /><w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text" /><w:LsdException Locked="false" Priority="1" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="No Spacing" /><w:LsdException Locked="false" Priority="60" SemiHidden="false"UnhideWhenUsed="false" Name="Light Shading" /><w:LsdException Locked="false" Priority="61" SemiHidden="false"UnhideWhenUsed="false" Name="Light List" /><w:LsdException Locked="false" Priority="62" SemiHidden="false"UnhideWhenUsed="false" Name="Light Grid" /><w:LsdException Locked="false" Priority="63" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 1" /><w:LsdException Locked="false" Priority="64" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 2" /><w:LsdException Locked="false" Priority="65" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 1" /><w:LsdException Locked="false" Priority="66" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 2" /><w:LsdException Locked="false" Priority="67" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 1" /><w:LsdException Locked="false" Priority="68" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 2" /><w:LsdException Locked="false" Priority="69" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 3" /><w:LsdException Locked="false" Priority="70" SemiHidden="false"UnhideWhenUsed="false" Name="Dark List" /><w:LsdException Locked="false" Priority="71" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Shading" /><w:LsdException Locked="false" Priority="72" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful List" /><w:LsdException Locked="false" Priority="73" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Grid" /><w:LsdException Locked="false" Priority="60" SemiHidden="false"UnhideWhenUsed="false" Name="Light Shading Accent 1" /><w:LsdException Locked="false" Priority="61" SemiHidden="false"UnhideWhenUsed="false" Name="Light List Accent 1" /><w:LsdException Locked="false" Priority="62" SemiHidden="false"UnhideWhenUsed="false" Name="Light Grid Accent 1" /><w:LsdException Locked="false" Priority="63" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1" /><w:LsdException Locked="false" Priority="64" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1" /><w:LsdException Locked="false" Priority="65" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 1 Accent 1" /><w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision" /><w:LsdException Locked="false" Priority="34" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="List Paragraph" /><w:LsdException Locked="false" Priority="29" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Quote" /><w:LsdException Locked="false" Priority="30" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Intense Quote" /><w:LsdException Locked="false" Priority="66" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 2 Accent 1" /><w:LsdException Locked="false" Priority="67" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1" /><w:LsdException Locked="false" Priority="68" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1" /><w:LsdException Locked="false" Priority="69" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1" /><w:LsdException Locked="false" Priority="70" SemiHidden="false"UnhideWhenUsed="false" Name="Dark List Accent 1" /><w:LsdException Locked="false" Priority="71" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Shading Accent 1" /><w:LsdException Locked="false" Priority="72" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful List Accent 1" /><w:LsdException Locked="false" Priority="73" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Grid Accent 1" /><w:LsdException Locked="false" Priority="60" SemiHidden="false"UnhideWhenUsed="false" Name="Light Shading Accent 2" /><w:LsdException Locked="false" Priority="61" SemiHidden="false"UnhideWhenUsed="false" Name="Light List Accent 2" /><w:LsdException Locked="false" Priority="62" SemiHidden="false"UnhideWhenUsed="false" Name="Light Grid Accent 2" /><w:LsdException Locked="false" Priority="63" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2" /><w:LsdException Locked="false" Priority="64" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2" /><w:LsdException Locked="false" Priority="65" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 1 Accent 2" /><w:LsdException Locked="false" Priority="66" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 2 Accent 2" /><w:LsdException Locked="false" Priority="67" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2" /><w:LsdException Locked="false" Priority="68" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2" /><w:LsdException Locked="false" Priority="69" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2" /><w:LsdException Locked="false" Priority="70" SemiHidden="false"UnhideWhenUsed="false" Name="Dark List Accent 2" /><w:LsdException Locked="false" Priority="71" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Shading Accent 2" /><w:LsdException Locked="false" Priority="72" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful List Accent 2" /><w:LsdException Locked="false" Priority="73" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Grid Accent 2" /><w:LsdException Locked="false" Priority="60" SemiHidden="false"UnhideWhenUsed="false" Name="Light Shading Accent 3" /><w:LsdException Locked="false" Priority="61" SemiHidden="false"UnhideWhenUsed="false" Name="Light List Accent 3" /><w:LsdException Locked="false" Priority="62" SemiHidden="false"UnhideWhenUsed="false" Name="Light Grid Accent 3" /><w:LsdException Locked="false" Priority="63" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3" /><w:LsdException Locked="false" Priority="64" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3" /><w:LsdException Locked="false" Priority="65" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 1 Accent 3" /><w:LsdException Locked="false" Priority="66" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 2 Accent 3" /><w:LsdException Locked="false" Priority="67" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3" /><w:LsdException Locked="false" Priority="68" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3" /><w:LsdException Locked="false" Priority="69" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3" /><w:LsdException Locked="false" Priority="70" SemiHidden="false"UnhideWhenUsed="false" Name="Dark List Accent 3" /><w:LsdException Locked="false" Priority="71" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Shading Accent 3" /><w:LsdException Locked="false" Priority="72" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful List Accent 3" /><w:LsdException Locked="false" Priority="73" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Grid Accent 3" /><w:LsdException Locked="false" Priority="60" SemiHidden="false"UnhideWhenUsed="false" Name="Light Shading Accent 4" /><w:LsdException Locked="false" Priority="61" SemiHidden="false"UnhideWhenUsed="false" Name="Light List Accent 4" /><w:LsdException Locked="false" Priority="62" SemiHidden="false"UnhideWhenUsed="false" Name="Light Grid Accent 4" /><w:LsdException Locked="false" Priority="63" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4" /><w:LsdException Locked="false" Priority="64" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4" /><w:LsdException Locked="false" Priority="65" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 1 Accent 4" /><w:LsdException Locked="false" Priority="66" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 2 Accent 4" /><w:LsdException Locked="false" Priority="67" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4" /><w:LsdException Locked="false" Priority="68" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4" /><w:LsdException Locked="false" Priority="69" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4" /><w:LsdException Locked="false" Priority="70" SemiHidden="false"UnhideWhenUsed="false" Name="Dark List Accent 4" /><w:LsdException Locked="false" Priority="71" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Shading Accent 4" /><w:LsdException Locked="false" Priority="72" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful List Accent 4" /><w:LsdException Locked="false" Priority="73" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Grid Accent 4" /><w:LsdException Locked="false" Priority="60" SemiHidden="false"UnhideWhenUsed="false" Name="Light Shading Accent 5" /><w:LsdException Locked="false" Priority="61" SemiHidden="false"UnhideWhenUsed="false" Name="Light List Accent 5" /><w:LsdException Locked="false" Priority="62" SemiHidden="false"UnhideWhenUsed="false" Name="Light Grid Accent 5" /><w:LsdException Locked="false" Priority="63" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5" /><w:LsdException Locked="false" Priority="64" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5" /><w:LsdException Locked="false" Priority="65" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 1 Accent 5" /><w:LsdException Locked="false" Priority="66" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 2 Accent 5" /><w:LsdException Locked="false" Priority="67" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5" /><w:LsdException Locked="false" Priority="68" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5" /><w:LsdException Locked="false" Priority="69" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5" /><w:LsdException Locked="false" Priority="70" SemiHidden="false"UnhideWhenUsed="false" Name="Dark List Accent 5" /><w:LsdException Locked="false" Priority="71" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Shading Accent 5" /><w:LsdException Locked="false" Priority="72" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful List Accent 5" /><w:LsdException Locked="false" Priority="73" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Grid Accent 5" /><w:LsdException Locked="false" Priority="60" SemiHidden="false"UnhideWhenUsed="false" Name="Light Shading Accent 6" /><w:LsdException Locked="false" Priority="61" SemiHidden="false"UnhideWhenUsed="false" Name="Light List Accent 6" /><w:LsdException Locked="false" Priority="62" SemiHidden="false"UnhideWhenUsed="false" Name="Light Grid Accent 6" /><w:LsdException Locked="false" Priority="63" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6" /><w:LsdException Locked="false" Priority="64" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6" /><w:LsdException Locked="false" Priority="65" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 1 Accent 6" /><w:LsdException Locked="false" Priority="66" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 2 Accent 6" /><w:LsdException Locked="false" Priority="67" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6" /><w:LsdException Locked="false" Priority="68" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6" /><w:LsdException Locked="false" Priority="69" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6" /><w:LsdException Locked="false" Priority="70" SemiHidden="false"UnhideWhenUsed="false" Name="Dark List Accent 6" /><w:LsdException Locked="false" Priority="71" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Shading Accent 6" /><w:LsdException Locked="false" Priority="72" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful List Accent 6" /><w:LsdException Locked="false" Priority="73" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Grid Accent 6" /><w:LsdException Locked="false" Priority="19" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis" /><w:LsdException Locked="false" Priority="21" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis" /><w:LsdException Locked="false" Priority="31" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference" /><w:LsdException Locked="false" Priority="32" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Intense Reference" /><w:LsdException Locked="false" Priority="33" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Book Title" /><w:LsdException Locked="false" Priority="37" Name="Bibliography" /><w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading" /></w:LatentStyles></xml><style> Style Definitions */table.MsoNormalTable{mso-style-name:"Table Normal";mso-tstyle-rowband-size:0;mso-tstyle-colband-size:0;mso-style-noshow:yes;mso-style-priority:99;mso-style-qformat:yes;mso-style-parent:"";mso-padding-alt:0in 5.4pt 0in 5.4pt;mso-para-margin-top:0in;mso-para-margin-right:0in;mso-para-margin-bottom:10.0pt;mso-para-margin-left:0in;line-height:115%;mso-pagination:widow-orphan;font-size:11.0pt;font-family:"Calibri","sans-serif";mso-ascii-font-family:Calibri;mso-ascii-theme-font:minor-latin;mso-fareast-font-family:"Times New Roman";mso-fareast-theme-font:minor-fareast;mso-hansi-font-family:Calibri;mso-hansi-theme-font:minor-latin;}</style>
