RCU Forums - View Single Post - Trimsolvent. NEVER AGAIN!!!!!
Old 02-13-2013 | 09:00 AM
Bax
Default RE: Trimsolvent. NEVER AGAIN!!!!!
From the tech notes:
"Harmful or fatal if swallowed. Vapor is harmful and combustible. Contains cyclohexanone, naptha, and gamma bytrol acetone. Do not
use or store near heat or flames. Use only in a well ventilated area. Avoid contact with eyes and prolonged contact with skin. If swallowed, give one or two glasses of water, and contact physician immediately."
The Manufacturer's Safety Data Sheet is available upon request.
The best way to use it is to put some onto a paper towel or cloth and lightly wipe the surface the trim is going to be put onto. Then lay the trim piece down. Too much solvent will dissolve the adhesive on MonoKote, and allow it to wipe off. It's best to not try to apply the trim solvent to the piece of trim for that reason. It is a very active solvent, and is intended for use with MonoKote.
