RCU Forums - View Single Post - The Why of Clark-Y
Old 02-14-2013 | 06:20 AM
abufletcher's Avatar
abufletcher
Default The Why of Clark-Y
Wikipedia has this to say about the prevalence of the Clark-Y airfoil in model airplanes:
"The Clark Y has found tremendous favour for the construction of model aircraft, thanks to the flight performance that the section offers at medium Reynolds number airflows. Application on model aircraft is very wide, ranging from free-flight gliders through to multi-engined radio control scale models.
The Clark Y is appealing thanks to its high camber, which produces a very good lift-to-drag ratio on comparatively lightweight balsa models, and for its near-horizontal lower surface, which aids in the accurate construction of wings on plans mounted on a flat construction board.
Young and inexperienced modellers are thus able to build model aircraft which provide a good flight performance due entirely to its aerofoil shape. The benign stalling characteristics of the airfoil are another aid, as this allows an inexperienced radio-control model hobbyist a better possibility of recovering from a stall in flight, to the benefit of the model.
The depth of the section lends itself to easier wing repair, as the modeller will often then have better access to balsa structural elements. In addition, the Clark Y section's depth also permits the flush installation of what are considered "standard" sized R/C servo motors within a wing for actuation of ailerons, flaps etc., without an excessive reduction in performance."
