RCU Forums - View Single Post - First Airplane!
Old 02-14-2013 | 10:53 AM
daytonarc
Default RE: First Airplane!
ORIGINAL: Summit is Beast!!!
Well I just ordered the super cub dsm rtf!! Cant wait to get it in the air!!! Thanks for the advice.
The HZ Super Cub DSM is a great plane. It is a 3 channel trainer with act that may help avoid major crashes. Like others have suggested you will probably do better if you locate a local club and get some initial help from an experienced flyer. Enter your zip code here http://www.modelaircraft.org/clubsearch.aspxto find a local club. The HZSuper Cub comes with a radio that you will be able to use for other bind n fly aircraft in the future and the reciever in it is 4 channels so when you get a little experience you can do an easy modification of adding ailerons to the plane. and disable the act to make it a much better flyer for someone with a little experience. Everything you ever wanted to know about the Super Cub and more is available here http://www.rcuniverse.com/forum/m_43...tm.htm#4371835
Good luck
