RE: ALIGN VS TAROT?
Mine didn't come with any electronics, so that's a non-issue. You can put whatever electronics you want in it and it will perform based on the components you select. I had a 450 SE for a while and comparing the two the finish on the parts for the Align heli was better. I expect the bearings to be better quality and more durable in the Align product, but I can't verify that until I fly it for a while. Something to understand though is that when comparing combo kits, there is the difference in price between the airframe and also a difference in the electronics and motor. The Tarot comes with Henge servos and a lower grade motor and ESC, while the Align comes with all Align parts. If you figure up the cost of outfitting a Tarot airframe with Align servos and power system the difference in cost isn't that much.
