RCU Forums - View Single Post - Fue level indicator in closed cowl (RAM)
Old 02-15-2013 | 08:52 AM
Iflier's Avatar
Iflier
Default Fue level indicator in closed cowl (RAM)
The RAM product is advertised to be installed with the sensor at the bottom of the tank and therefor the lamp would turn on when the fuel level is getting low. The lamp would be placed in a visible location on the plane and therefor indicate the need for a swift landing before running out of fuel.
I needed a slightly different approach.
Check out the blog and let me know what you think. I could have stuck with the fuel dripping out of the vent line but this was more fun.
www.iflier.blogspot.com<a target="_blank" href="http://www.iflier.blogpot.com">
<br type="_moz" /></a>The topic is labbelled <span style="font-size: smaller; "><span style="color: rgb(0, 0, 0); ">'</span></span><span style="color: rgb(0, 0, 0); "><span style="text-decoration: none; font: normal normal bold 16px/normal Arial, Tahoma, Helvetica, FreeSans, sans-serif; color: rgb(0, 0, 0); "><span style="font-size: smaller; "><span style="color: rgb(0, 0, 0); ">Testing and Installation of Fuel Fill Indicator</span></span></span><span style="font-size: smaller; "><span style="color: rgb(0, 0, 0); "><span style="text-decoration: none; font: normal normal bold 16px/normal Arial, Tahoma, Helvetica, FreeSans, sans-serif; ">'</span></span></span></span>
