RE: Ed's Ziroli B-25 Build
And the build continues.....
First had to glue on the W-8 on the other side. Again, the angled aluminum comes in real handy with a few cheap triangles from home depot. Im hoping the effort will give me a nice gapless joint when I'm done.
Once that was done I flipped her up and added the remaining spars to the bottom. I used this opportunity to prep the ribs with the flaps so they will be easier to cut later on.
Next I made the skins for sheeting the bottom of the wing. I carefully blocked up the wing so that while i was adding the skins I didn't inadvertently build in a warp. There is still one more skin to add to the bottom, but Its been a long day and I need to get some sleep!
