RE: Phoenix 6 - Start # 2
This should be last post before final, and finish. First picture, little fuzzy. This is a brass tube, which is 36" long. I insert it from the servo bay area, back to the pushrod exits. This will be cross set up. After tube in, then the coated stranded wire pushed thru, easy exit to back, pull the tubinh out, line is there for hookup. Repeat other side. No other support straight run. Smaller planes you can do that. Picture of Rocket City 440 horns at back, just run thru after measure, to make sure 180. Last picture, ideas for the two P-8's, Kato paint jobs.
Crank
