RE: Ed's Ziroli B-25 Build
Building the outer wing panels is pretty easy once I figured out the arrangement of all the spars. Started off by laying the 1/4"sq over the plans which I guess builds in some washout. I didnt glue the inner rib W-9 (which mates to the center section) so that way I can get a nice tight fit as I align the wing panels.
I do have a question if anyone wants to take a stab at it- Once the panel is done and I take it off the table, its still pretty flimsy and easily warped. It looks like I am supposed to sheet the bottom first- how on earth do I keep from warping it as I put the sheeting on if I sheet the top first without the use of the 1/4sq on the board? I am sure the answer is simple, but I'm just not seeing it.
